2003 Hyundai Elantra Windshield Beam Repair
HYUNDAI
TIA12875
my car was stolen over the weekend and recovered the next day. The beam along the driverside of the windshield was bashed in pretty good and the windshield is cracked up. The auto shop that i use is wanting to cut out that piece and weld in a piece from a junk yard car to make the repair. Is this safe? I am feeling very uneasy about this.
This is a 03 Hyundai Elantra GLS with 87K miles.
thanks
tera
Apr 10, 2007 at 2:11 AM
BRUCE HUNT
  • 3,754 POSTS
I would not feel too bad about that being done as long as it is done properly. There really isn't much else they can do for a repair that makes any sense with that area of the car. I wouldn't worry too much.
Apr 10, 2007 at 7:33 AM
Suggested Repair
A properly performed section repair is acceptable: cut out the damaged windshield beam and weld in a matching donor section, then replace the cracked windshield. Confirm the shop uses correct welding, alignment, and corrosion protection.
Conversation Summary
The owner of a 2003 Hyundai Elantra recovered after theft has a badly damaged driver's-side windshield beam and a cracked windshield. The shop proposes cutting out the damaged section and welding in a piece from a donor car. The expert says this is a reasonable repair if done properly, because few other sensible options exist for that area.
