blower motor
HYUNDAI
DINOMETIV
Hi i have a 95 hyundai accent and the blower would only work on high last night and then finally it quit altogether.First,i would like to know where to access it (under hood or dash) and if possible,how to test it.thank you,dinometiv
Feb 16, 2006 at 4:19 AM
PEPPERMRJ
  • 1,158 POSTS
The blower motor is located a the right side of the dash at the passengers footwell. Remove the electrical connection, the cooling tube, and the three retaining bolts for removal.
Connect either a test light or voltmeter to the connector to see if power is present.
Good luck and let us know.
Feb 16, 2006 at 7:34 AM
DINOMETIV
Thank you for the info..i checked around while waiting for a response and you were right on the money.I was going to wait till tommorrow because of a bad storm but i sucked it up and found it.Thanks for the info.Will definitely visit the site more often.
Feb 16, 2006 at 11:33 AM
