1999 Hyundai Accent Downstream O2 Sensor Fix
1999 HYUNDAI
JOHNEJR
How do I replace sensor number two on the car , it appears to be the one down stream form the converter , I had the diagnostic scan done and came up with fault code P0136 and I think this is the sensor located in the exhaust pipe . Can I replace it without going to a lot of extremes. The engine is this car is a 1.5 lLiter SOHC . Th car has about 76000 miles on it .
also if I do replace the sensor myself do I have to have the computer reset or is there a trick to resetting the computer without going to the parts store and resetting with the scanner .
Jan 11, 2007 at 2:28 PM
BRUCE HUNT
  • 3,754 POSTS
Don't know the engine that you have but if this is a four banger engine there should be only one lower O2 sensor. So, here is my advice. Get an exact replacement is can even be an aftermarket one but get one with the connections on it. Now locate the sensor and cut the wires close to the sensor so that you can get a wrench or socket on. It will come loose but it may be tough and fighting those wires is tough. Insert the new one, tighten with and open end wrench and connect wiring. Good luck!
Jan 12, 2007 at 1:38 AM
Suggested Repair
Replace the downstream O2 sensor with an exact-fit unit that includes the connector. Cut the old sensor wires close to the sensor so a wrench or socket can reach it, remove the sensor, install the new one, tighten it with an open-end wrench, and connect the wiring.
Conversation Summary
The owner of a 1999 Hyundai Accent 1.5L SOHC with about 76,000 miles asked how to replace the downstream O2 sensor after a scan showed code P0136, and whether the computer must be reset afterward. The expert said a four-cylinder should have one lower O2 sensor and advised using an exact replacement with connectors, cutting the old wires near the sensor for wrench access, installing and tightening the new sensor, and connecting the wiring. The reset question was not answered.
