Yes it is possible to bend those valves, the best way to check this is by doing a leak down test on the valves with a leak down gaugen other easy ways would be to pull off valve cover and inspect valves, pull spark plugs to check 4 damage and try to look down into cylinders with a pen light, look for marking on pistons from valve contact or other debris
SPONSORED LINKS
Monday, May 28th, 2007 AT 12:21 AM
