1999 Hyundai Accent Light Surge
1999 HYUNDAI
APPLE_JACKS
I have a '99 accent and recently all the lights (headlights, dash lights, etc) have begun to surge brighter/dimmer about 2-3 times a second. The problem doesnt seem to be affected by engine RPM. The alternator was replaced about 40k ago due to a fauty voltage regulator that displayed different symptoms (headlight bulbs blowing etc). The problem is getting worse and has just recently started to cause the vehicle to jerk when driving slowly at low RPM. Any ideas?
Sep 2, 2007 at 2:03 PM
  • 75,988 POSTS
[quote:035ae93ed4="apple_jacks"]I have a '99 accent and recently all the lights (headlights, dash lights, etc) have begun to surge brighter/dimmer about 2-3 times a second. The problem doesnt seem to be affected by engine RPM. The alternator was replaced about 40k ago due to a fauty voltage regulator that displayed different symptoms (headlight bulbs blowing etc). The problem is getting worse and has just recently started to cause the vehicle to jerk when driving slowly at low RPM. Any ideas?[/quote:035ae93ed4]
Have the charging system check-and check the battery connections especially the ground cable to the engine.
Sep 2, 2007 at 6:16 PM
Suggested Repair
Have the charging system checked and inspect the battery connections, especially the ground cable to the engine.
Conversation Summary
The owner of a 1999 Hyundai Accent reports lights surging brighter and dimmer several times a second, unrelated to engine RPM. The alternator was replaced about 40,000 miles ago, and the worsening issue now causes jerking at low RPM. The expert advises checking the charging system and battery connections, especially the engine ground cable.
