HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Hyundai
Elantra
Engine
Symptoms
Not Running
2003 Hyundai Elantra WONT start when its hot
KLB315
MEMBER
2003 HYUNDAI ELANTRA
4 CYL
2WD
AUTOMATIC
129,485 MILES
Won't start when it hot
Monday, June 21st, 2010 AT 12:18 PM
BLUELIGHTNIN6
MECHANIC
Hello and thanks for donating
May want to look into a faulty Crank Sensor and or a faulty Ignition Module. The Crank Sensor is the most likely culprit. Often, neither of these components will set any codes.
Monday, June 21st, 2010 AT 4:09 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
Lost All Coolant/water Via Hose That Came Lose. Car...
Driving On The Interstate About 75 Mph My Car Started To Lose Power. Dropped To 40 Mph Quickly Then As I Was Braking To Get The Car Stopped...
Asked by
vettemanusa
1 ANSWER
2003
HYUNDAI ELANTRA
VIDEO
Car Cranking but Not Starting? Try This
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
2003 Hyundai Elantra Car Won't Start When Hot
Our Hyundai Elantra Will Start While Its Cool But When You Drive Somewhere And Get Back In To Return Home It Won't Start. The Engine Light...
Asked by
amyasu89
1 ANSWER
2003
HYUNDAI ELANTRA
Does Not Start On The First Or Second Crank
The Car Will Not Start On First Crank Or Second. Have Been Waiting A Short Time Then Trying To Start It. Cranks And Fires Up. Sometimes...
Asked by
cmzannn
1 ANSWER
2003
HYUNDAI ELANTRA
Not Starting
When It Would Not Start If I Moved Shifter Down And Back It Would Start. Today It Would Not. Why? Thanks
Asked by
cmzannn
1 ANSWER
2003
HYUNDAI ELANTRA
Not Starting
If I Get The Gear Shift And Wiggle It Or Turn Key On Go Up And Back Turn Key Hear Click Then Start It. Why?
Asked by
cmzannn
1 IMAGE
2003
HYUNDAI ELANTRA
VIEW MORE
How to fix an engine that wont start
Crankshaft Sensor Replacement
