2003 Hyundai Elantra my 2003 Elantra is over heating!
ALLYNNSMITH
  • 2003 HYUNDAI ELANTRA
  • 4 CYL
  • FWD
  • 97,659 MILES
My car is overheating, after about 15 mins of driving I notice the needle going up to the mid way mark, now usual my needle stays at about a quarter of an inch below that, if I turn the heater on all the way high, it cools right off. Today I had to do a bit more driving then normal, and its 72 degrees here in virginia beach, and even with the heater on fulll blast, the needle raise to be higher then the middle hatch mark, and when I slowed down it dropped down to the almost normal spot, oh and also if I am at a full stop the needle goes back to its normal position under the halfway mark also its a 2003 hyundai elantra gls
Thursday, October 22nd, 2009 AT 5:45 PM
Replace the thermostat and make sure the coolant level is okay
Thursday, October 22nd, 2009 AT 6:00 PM
ALLYNNSMITH
Thank you, any idea how much that usually runs? Is it something I can do myself?
Thursday, October 22nd, 2009 AT 6:32 PM
Dunno the costs it varies with location -The thermostat is located on the engine follow the upper hose till its meets up to the thermostat housing where the hose ends its behind it-You can do this yourself
Thursday, October 22nd, 2009 AT 6:38 PM
