6 years ago, I ran out of gas. Ever since it takes 3-5 seconds of cranking to start. Now it is getting worse and I have to stop cranking and try again. It will usually start on 2nd crank but occasionaly will start dieseling and I have to shut it off and the 3rd crank starts right up. I have replaced the fuel filter, fuel pump, spark plugs, spark plug wires, and air filter. Just recently I got a check engine light and the code indicated a cylinder 4 misfire. Mechanic replaced the coil, plugs, and wires and it is back to 2-3 cranks before it starts but does seem to continue to get worse.
SPONSORED LINKS
Wednesday, August 18th, 2010 AT 9:52 PM
