2000 Hyundai Elantra Engine cranks but wont start
HARACER
  • 2000 HYUNDAI ELANTRA
  • 4 CYL
  • FWD
  • 115,000 MILES
2000 Hyundai just cut off while driving no the car just cranks very loosely as if its not on timing. So far ive check the starter, fuel system, ignition system, crankshaft poisition sensor. Car gets spark and fuel but will not start. Intially car was off timing but after correcting timing still wont start, after doing a compression test I found that there is no compression all the way across.
im lost at this point and just looking for any educated guesses that anyone has
Saturday, March 13th, 2010 AT 5:45 PM
CARADIODOC
  • 33,916 POSTS
Since the timing belt was off, suspect bent valves causing the loss of compression. Thank you for providing good information. The next place to turn is a cylinder leakage test. That involves putting each cylinder, one at a time, on top dead center on the compression stroke, then applying regulated compressed air through the tester into the spark plug hole. The tester will indicate the percent of leakage, and you can listen for where the leakage is occurring:
1. Tail pipe - bent exhaust valve.
2. Air intake / throttle body - bent intake valve
3. Oil fill cap - worn piston rings.
4. Bubbles in radiator or reservoir - leaking head gasket or cracked head.
If you didn't replace the timing belt, consider doing so. It jumped for a reason, usually because a few teeth are missing.
Caradiodoc
Saturday, March 13th, 2010 AT 6:08 PM
HARACER
Did a leak down test and everything tested good, replaced the camshaft sensor, still nothing, then I discover that the cam gear wasnt lined up correctly with timing chain gears and the reason was that the pin on the timing gear was broken so the gear moves without turning the gear, gonna try and get my hands on a new camshaft and pin or try to get the old one machined, we'll see if that works!
Monday, March 15th, 2010 AT 10:12 PM
CARADIODOC
  • 33,916 POSTS
Dandy observation. How did you discover the broken dowel pin? This is actually a fairly common problem with Dodge Neons but those are interference engines. The Engine Computer sees the camshaft and crankshaft position sensors out-of-sync and shuts the engine down to prevent engine damage.
It sounds like your engine is not an interference engine so no valves got damaged. You don't have to replace the camshaft or sprocket. The pin usually isn't too hard to remove. Sometimes you can use epoxy to glue a piece of wire to the pin, then pull it out. Another method is to use a wire feed welder to weld a small bolt to the pin. The hole in the sprocket usually goes all the way through, so you can just punch the pin out.
Caradiodoc
Monday, March 15th, 2010 AT 10:29 PM
