2000 Hyundai Elantra Car will not start.
CAPTAINESPINOSA
  • 2000 HYUNDAI ELANTRA
Engine Mechanical problem
2000 Hyundai Elantra 4 cyl Front Wheel Drive Automatic
2 months ago I replaced the Catalytic Converter and combustion sensor. Monday I went to start her; she would crank but will not turn over. The fuel pump vibrates when I turn the key so I assume it is not the pump. What do you think about this?
I am thankful for you help.
Thanks
Dan Espinosa
captainespinosa@yahoo. Com
Wednesday, January 27th, 2010 AT 7:18 AM
  • 109,885 POSTS
Dan:
I need you to check if the engine is getting spark and fuel. Even thought the pump is running, it may not be producing enough pressure to run the engine.
Here are the how to's for checking both. Most parts stores will lend or rent the needed tools for the checks.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
Let me know what you find.
Wednesday, January 27th, 2010 AT 1:38 PM
