If it starts with starting fluid, then the problem is with the fuel system. Chances are the fuel pump isn't building enough pressure for it to start. You need to check it. Here is a how to for checking fuel pump pressure:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Check it and let me know what you find. If you need the pressure gauge, many parts stores will lend or rent one to you.
Let me know what you find.
SPONSORED LINKS
Wednesday, January 27th, 2010 AT 11:11 PM
