I thought it was all vacuum. As far as a schematic, I sent the only one for the HVAC system that is listed in my manual. I checked the S10 and it's the same one.
Are you looking for something different?
SPONSORED LINKS
Monday, January 4th, 2021 AT 9:01 AM
(Merged)
ED SCARFF
MEMBER
1 POST
I have the same problem with my 96 S10. Can you send the vacuum schematic?
(Merged)
STEVE MEENTS
MEMBER
2000 CHEVROLET BLAZER
150,000 MILES
Need to repair air plenum door inside air flow box.
(Merged)
STEVE W.
MECHANIC
Which one? Most of them require you to pull the dash and the HVAC box to do anything. Have you tested to be sure it is not just a bad actuator?
(Merged)
STEVE MEENTS
MEMBER
Got door plenum to move freely. I got the old actuator out with some difficulty ( big hands ) bought new one and am having hard time aligning and installing. Do I need to pull dash out?
SPONSORED LINKS
(Merged)
STEVE MEENTS
MEMBER
On this 2000 Blazer the actuator sits at the very top next to dash board.
(Merged)
STEVE W.
MECHANIC
OK you're working through the glove box on the temperature actuator correct? There isn't much room but you can get it in there with a bit of fiddling.
