1999 Chevy Blazer HEATER HOT AND COLD
KBEMIS69
  • 1999 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 115,000 MILES
RECENTLY MY COMPUTERIZED CLIMATE CONTROL HEATER BEGAN BLOWING HOT AND COLD ALTERNATELY. I CAN HEAR THE CONTROL DOOR OPEN AND CLOSE CONSTANTLY. ALSO THE HEAT DOESN'T SHUT OFF WHEN TURNED DOWN OR OFF. COOLANT FINE. THERMOSTAT FINE.
Saturday, January 19th, 2008 AT 1:47 PM
DENNYP
  • 1,824 POSTS
You will always have a small amount of heat from the vents while driving. You probably have a bad HVAC comtrol head causing your other problem.
Saturday, January 19th, 2008 AT 5:21 PM
