1996 Chevy Blazer Vehicle completely dies when the heater i
MPKEEGAN
Electrical problem
1996 Chevy Blazer 6 cyl Four Wheel Drive Automatic
The blazer will die when you turn on the heater, regardless if you are driving or sitting. It completely kills the vehicle. The main interior light will not turn off. The battery is fully charged, but the blazer will not even register it has power now when you turn the ignition.
Nov 8, 2009 at 7:53 AM
  • 110,244 POSTS
If nothing is working, check to make sure all battery terminals and grounds are good. Also, have you checked the ignition switch? Finally, does anything happen when you turn the key to start?
Nov 13, 2009 at 2:37 AM
MPKEEGAN
[quote:66afe8bd36="Jacobandnickolas"]If nothing is working, check to make sure all battery terminals and grounds are good. Also, have you checked the ignition switch? Finally, does anything happen when you turn the key to start?[/quote:66afe8bd36]
I got absolutely no response from the vehicle when I try to start it, nothing at all. I checked all the cable grounds. Still nohting...
Nov 16, 2009 at 1:55 AM
