1992 Honda Prelude Vibration in Gear
replace the one you are waiting for and check the rest of them..
Is the tranny fluid full and is the fluid clean in appearance?
"Lately my idle has been jumping up and down whenever i let go off gas to slow down. When the idle goes down I can feel the car trying to slow down, but as soon as it does or a step on the brake the idle jumps up and car is trying to speed up. Also, when i press on the brakes and car is almost at full stop, idle jerks a little, goes down to 1000 rpms, and then after couple seconds down to like 750-800. When at a full stop, I let off the brake on a hill, it speeds up and changes gears, but only goes in first."
^ this person has the exact same problem as me, and wrote it out much better than i could have.
Suggested Repair
Replace the broken engine mount and inspect the remaining engine and transmission mounts. Confirm the transmission fluid is full and clean before treating the faint delay as a transmission slip.
Conversation Summary
The owner of a 1992 Honda Prelude automatic reported hard jerks when selecting a gear and strong vibration at idle, including visible exhaust movement while holding the brake in Drive. Vibration was minimal while driving. Experts advised replacing the broken engine mount, checking the other motor and transmission mounts, and verifying whether the hesitation came from the engine or transmission and whether the fluid was full and clean. After the broken mount was replaced, shifting improved slightly, but idle vibration remained and the owner still suspected faint transmission slip from a stop.
