2001 Honda Prelude Front End Shake
CAPTAIN OF THE TODDS
I have a 01 Honda Prelude (2.2 v-tech). I recently hit a pretty decent size pot hole and now I am having an issue with the front end. The front end is bouncing, I'm not sure which side it is coming from (I have a feeling that it is the right side). The steering wheel shakes horribly; however there doesn't seem to be an alignment issue because the car will still go straight if I let go of the wheel. I'm trying to get an idea of what it may be so that I can try some things myself without having to take it in. Any ideas?
Mar 20, 2007 at 4:48 AM
BRUCE HUNT
  • 3,754 POSTS
A couple of things come to mind. First, is the lift the front end and rotate the tires. Observe the rim to ensure that it is true. Look at the tread and note any pattern of shifting as the wheel rotates. You might have a cord that has been broken.
Next I would look to see if the wheel weights that were probably installed have fallen off.
Another thing to look at is the front suspension to see if anything is bent.
If none of these tell you the answer, I would take it to the alignment rack.
Mar 20, 2007 at 6:22 AM
Suggested Repair
Lift the front end and rotate the tires, checking that the rims are true and looking for tread shift that may indicate a broken cord. Check whether wheel weights have fallen off and inspect the front suspension for bent parts. If those checks do not explain the shake, have the car checked on an alignment rack.
Conversation Summary
The owner of a 2001 Honda Prelude reported front-end bouncing and severe steering-wheel shake after hitting a pothole, while the car still tracked straight. The expert suggested checking the tires and rims for damage or a broken cord, looking for missing wheel weights, inspecting the front suspension for bent parts, and using an alignment rack if those checks do not find the cause.
