1999 Honda Prelude No Spark
Suggested Repair
With the coil and distributor already replaced and the engine cranking but producing no spark, test the crankshaft position sensor behind the timing cover at the bottom of the engine, behind the harmonic balancer. Also confirm 12-volt power to the ignition coil and related ignition circuit before suspecting the ECU.
Conversation Summary
A 1999 Honda Prelude began running rough with misfire codes after repeated battery failures, then cranked but would not start with no spark. The owner replaced the ignition coils and distributor, which includes the camshaft position sensor, but still had no spark while fuel was present. The expert advised checking spark and coil power, then pointed to the crankshaft position sensor behind the timing cover near the harmonic balancer. The owner asked whether the ECU or the earlier dead battery could be involved, but that was not confirmed.
