1997 Honda Prelude No Spark
1997 HONDA PRELUDE
177,000 MILES • 6 CYL • FWD • AUTOMATIC
LAPSEAL
I have a 1997 Honda Prelude 177K
the following has been done to this car.
1/ replace plugs with ngk
2/ new rotor & cap
3/ new ignitor
4/ new main relay
5/ new battery terminals
6/ new coil
checked all fuses and even the fuel pump. Put the banjo connector in a quart jar, turned on the ignition and it fill the jar very quick.
Still no spark, even Honda tech looked puzzled.
I will pay good money to the perosn who solves this mystery???
Feb 19, 2010 at 8:44 AM
KHLOW2008
  • 41,814 POSTS
Hi lapseal,
Was any repairs carried out prior to this occurring?
Possible causes for no sparks apart from some of the items that you have replaced are :
1. PCM.
2. Ground circuit. Check the connections at right side of engine.
3. Timing belt.
4. Ignition switch. Ensure voltage is available at the distributor Black/Yellow wire at ignition switch ON AND while cranking.
Feb 27, 2010 at 1:34 PM
