1994 Honda Prelude parking/signal lights
1994 HONDA PRELUDE
STEELCALLER
Electrical problem
1994 Honda Prelude 4 cyl Front Wheel Drive Manual
Ok so my right front turning signal does not come on in my 94 lude, not at anytime not as a parking light or as a hazard or turning signal, i hooked it up to my meter and it only shows about 4 volts getting to the light and a full 12 getting the the side that is working... does anyone have a smart idea about what could be wrong? From what I've read i doubt its the turning relay sense it wont come on as a parking light either... but idk, why am i losing 8 volts of power? where should i start looking? o and another great lil thing is that even with all power off there is still 4 volts going to the broken side... and the 0 volts going to the working side like you would expect...
Aug 28, 2010 at 8:36 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Seems as though you have a ground issue. Check the ground wiring to that specific bulb housing and repair it as needed. Let me know how it goes.
Aug 28, 2010 at 3:17 PM
