1989 Honda Prelude No right side turn signals or hazard bli
187,000 MILES • 4 CYL • FWD • AUTOMATIC
DGROHNE
  • 5 POSTS
The running lights, headlights, backup lights, and left side turn signals/hazard lights all work, but no turn signals/hazard lights work on the right side. Have checked all bulbs and cleaned dirt from all sockets. Wiring appears to be OK.
Feb 25, 2009 at 2:29 AM
KHLOW2008
  • 41,812 POSTS
Hi dgrohne,
I would suggest checking the Directional/Hazard Relay.
Test Green/Yellow wire for battery voltage with hazard switch turned ON. If no voltage is present, the relay is bad.
Feb 25, 2009 at 4:52 AM
DGROHNE
  • 5 POSTS
Sometimes the simple things fix the problem. I reseated the wiring harness going into the relay box and the blinkers are back!
Feb 28, 2009 at 11:10 AM
