1994 Honda Prelude acceleration & iddle
1994 HONDA PRELUDE
167,000 MILES • 4 CYL • FWD • MANUAL
ROBLOKO760
when i am driving and i am accelerating the car feels like it is showking and does not goes that fast and 5 seconds later the car starts going the adecuate speed. also when i am driving and put the car in neutral as i am getting to a stop sign or red light the car turns off.. eventhough i am going 25 miles a hour
Nov 30, 2009 at 12:21 PM
Your possibilities as follows:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Nov 30, 2009 at 8:57 PM
