Checking transmission fluid
CHRSLE
  • 1999 HONDA PASSPORT
  • 6 CYL
How do I check and or change the transmission fluid in my 1999 honda passport?The dip stick is not under the hood. Me nor anyone that has searched for it can find it under the hood. Please help me!
Monday, February 7th, 2011 AT 11:11 PM
To check the transmission fluid you must do it from under the car you basically push fluid in until the fluid comes out of the fill hole like the old stick shift transmissions. Here are diagrams below to show you. Please let us know if you need anything else to get the problem fixed. Cheers.
Wednesday, September 26th, 2018 AT 2:53 PM
KEITH1111
How many quarts trans fluid it takes and can I put it in myself thank you much?
Wednesday, November 25th, 2020 AT 6:44 PM (Merged)
Refill it a the overfill screw while engine is idling atleast 3 mins the fluid will seek correct level and excess fluid wil exit from the overfill screw-Good Luck
https://www.2carpros.com/forum/automotive_pictures/12900_fill_1.jpg
JIMDONAHOE
  • 89,500 MILES
Two problems. Maybe related
1. I am going through transmission fluid. I drove from La Paz Mexico to Washington State and went through 3 quarts of transmission fluid and now it feels like it is low again.
2. When I put the car in drive there is a noise and sometimes it seems to take some time to fully engage into a gear. This especially happens when the transmission level is lower. It seems like there is a fan that is making the noise.
  • 110,182 POSTS
Is there any evidence of a trans fluid leak? Also, it is normal for the delayed shift if the fluid is low.
JIMDONAHOE
I do not see any evidence of a transmission fluid leak.
The challenge with the delayed shift only started during my trip from Mexico to Washington.
  • 110,182 POSTS
Okay, don't laugh. When the engine is cold, check coolant in the radiator and make sure the ATF isn't mixing with the coolant. It has to be going somewhere.
BUCKU2
  • 1996 HONDA PASSPORT
Transmission problem
1996 Honda Passport 6 cyl Four Wheel Drive Automatic 206.00 miles
how much does it hold?
Transmission Fluid
2WD/4WD Initial Refill 8.6 liters (9.1 quarts)
Fluid Type DEXRON-IIE Automatic Transmission Fluid
CJ9113
1996 Honda Passport 6 cyl Automatic 154000 miles
I think my transmission is slipping, when I stop my car idles really fast and when I am on park it also does it. I want to know where I can check my transmission fluid and put it some in?
Fluid Check
Park vehicle on level ground, then apply parking brake.
Place gear selector in Park, then start engine and allow to idle for two minutes.
With the brake pedal depressed, move gear selector through all gear ranges, ending in Park.
https://www.2carpros.com/forum/automotive_pictures/12900_t_2.gif
Let engine idle for 3 minutes and then open the overfill screw.
Add transmission fluid until it flows out over the overfill screw-opening.
Let the engine idle until a fluid temperature between 32 °C (90 °F) and 57 °C (135 °F) is reached, then close the overfill screw and torque to 38 Nm (28 ft.lbs)
CAUTION
Do not check fluid level under the following conditions:
Immediately after driving at sustained highway speeds.
Immediately after driving in heavy traffic during hot weather.
Immediately after driving while towing.
Wednesday, November 25th, 2020 AT 6:45 PM (Merged)
SHAWMICHELLE
  • 1998 HONDA PASSPORT
Six cylinder four wheel drive automatic 151000 miles.
I cannot find where to check the transmission fluid or put it in and it is slipping. Can you help me please?
Tuesday, December 1st, 2020 AT 12:05 PM (Merged)
ZACKMAN
  • 4,202 POSTS
Hi shawmichelle,
The following reply has a description of what needs to be done. You need to pump the fluid in from the bottom and let it run from the fill plug telling you it is full. Not like the old days of a dip stick.
If you require more information, feel free to ask.
https://www.2carpros.com/forum/automotive_pictures/55316_98passportatf_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_98passportfig2_1.jpg
Please let us know what you find.
Cheers
