1999 Honda Passport Trouble taking car out of park?
1999 HONDA PASSPORT
WARREN51670
Other Category problem
1999 Honda Passport V6 Four Wheel Drive Automatic 109000 miles
I have a 1999 Honda Passport. When you put it in park the button that you push in to take it out of park wont go in??? Once you get it out of park you can move it to all out gears but once in park again it take along time to be able to change again. PLEASE HELP !!
Dec 3, 2007 at 7:59 AM
DAVEINSIERRAS
  • 6 POSTS
I had a similar problem on my 2000 Passport. Turns out, there is a cable that runs from the auto shift lever up to the ignition switch. When the lever is put in park, it moves the cable which disengages a nylon "stop" allowing the igntion key to be turned either to the on or off position. This is to prevent the car from being started in anything but "park". Look for problems in the linkage either at the shift or at the ignition. On my Passport, a tiny screw at the ignition end had come loose.
Aug 29, 2008 at 6:41 PM
