Honda Broken Wheel Studs
HONDA
POSHONDA
Recently I had a Wheel nut stud break on me when i over-torqued the lugnut. I had enough to put a lugnut back on securely, or so I thought. I got about 40 miles on it, when i noticed that my car was shaking like a nut was loose. So I get home and check it out and find out that 2 wheel nuts are completely broken off. I bought a chiltons manual to get info on how to replace them and it is extremely confusing on whether on how to take off the caliper and if what i should do after I get the caliper off. So how do I go about replacing these studs?
Nov 12, 2006 at 8:15 AM
BRUCE HUNT
  • 3,754 POSTS
Take off the rotor and using a punch and hammer on the broken ones and hammer on the bad one knock them out of wheel assembly backwards. NAPA carries the nut and stud usually in stock. Use caution in putting them back on to avoid excessively harming the threads. Snug them down to pull the locking mechanism in to place. Now try not to over tighten them!
Nov 12, 2006 at 11:21 AM
Suggested Repair
Remove the rotor and use a punch and hammer to knock the broken studs out of the wheel assembly from the back. Install replacement studs and nuts carefully so the threads are not damaged, snug them enough to seat the locking mechanism, and do not overtighten.
Conversation Summary
The owner over-torqued a lug nut and broke a wheel stud, then found two studs broken after the Honda began shaking. An expert advised removing the rotor, punching the broken studs out backward, installing new studs carefully, and avoiding overtightening.
