Honda Front Wheel Studs Stuck
HONDA
POSHONDA
I am trying to replace my wheel studs on my front wheel. I have removed the rotor and have not been able to remove the plate so I can take the studs out. I can remove the Big Middle nut, but i can't figure out how to remove the plate. I tried using an extractor, but that was a no go. Any help>?
Nov 28, 2006 at 5:03 AM
BRUCE HUNT
  • 3,754 POSTS
You can get a service manual and it will most likely show you how that assembly is fit together. I simply knock them out with a hammer and try my best to be as gentle as possible in putting in the new ones to eliminate as much thread wear as possible. A little grease to help reduce the friction as you tap the new one in to place. Not the perfect way to do it but it was effective and I had no problems with threads.
Nov 28, 2006 at 8:02 AM
Suggested Repair
Consult a service manual for how the hub assembly fits together. Knock the old wheel studs out with a hammer, then lightly grease the new studs and tap them in gently to reduce friction and thread wear.
Conversation Summary
The owner removed the front rotor and large center nut but could not remove the plate to replace the wheel studs, and an extractor did not work. The expert recommended a service manual for the assembly and said the studs can be knocked out with a hammer; grease the new studs and tap them in carefully to limit thread wear.
