2002 Honda Civic Broken O2 Sensor
JRT160
I broke my 02 sensor while trying to change it , and was wondering if the car will die on me if driven without it temporarily....thanks
Jan 30, 2007 at 9:57 AM
BRUCE HUNT
  • 3,754 POSTS
Which one did you break? There are more than one. Now if it is the bottom one and I say this based on a guess that you have a 4 cylinder, you might notice a small idle problem and a loss of fuel economy. The upper O2 may cause the idle to be worse, etc. I have driven with the lower disconnected for about a 1000 miles without any noticeable difference. I would imagine and hope that the check engine light is on.
Jan 30, 2007 at 10:01 AM
JRT160
Actually i didn't know there were more then one on it, but it is the one right below the manifold.
Thanks for your help.
Jan 30, 2007 at 10:06 AM
BRUCE HUNT
  • 3,754 POSTS
That is the most critical one and I would get it replaced very soon. They are available at the local car parts store or online. Can't remember the website but the is one that just handles O2 sensors and they carry them all. They were quite reasonable. They have them on ebay.
Replace it. You car will thank you and the environment will thank you too!
Jan 30, 2007 at 2:08 PM
Suggested Repair
Replace the oxygen sensor just below the exhaust manifold as soon as possible. It is the most critical sensor; driving without it may cause idle problems, poorer fuel economy, and a check engine light. Replacements are available from parts stores and online sellers.
Conversation Summary
The owner of a 2002 Honda Civic broke the oxygen sensor just below the manifold while replacing it and asked whether the car could be driven temporarily without it. The expert identified that sensor as the most critical one and advised replacing it very soon. Driving without it may cause idle issues, reduced fuel economy, and a check engine light.
