1991 Acura Legend Stalls and Loses Power
Suggested Repair
Compare idle and power with the catalytic converter connected and disconnected to see if a restricted converter is causing the stalling and power loss. Given the low mileage, also check for an overcharging battery as the source of the rotten-egg smell, and verify ignition timing and that no check-engine light is present.
Conversation Summary
A 1991 Acura Legend with 49,000 miles began stalling at low idle and had hard brakes; a vacuum leak was repaired, then the injectors were cleaned after it stalled again. The car still lacks power, uses more fuel, runs very hot underneath, and has a rotten-egg smell, while a scan showed no faults and the shop suspected the catalytic converter. The expert suggested comparing a run with the converter connected and disconnected, noted the mileage is low for converter failure, asked about the check-engine light and timing, and said the smell can come from an overcharging battery.
