1965 Honda Loss of Power Uphill
1965 HONDA
QUAMPUS22
My Honda losses power and literrily stalls while going uphill at 65 mph.
I have replaces all ignition parts but still have the problem.
Can you help? :(
Dec 31, 2006 at 1:55 AM
IDEISLTECH
  • 5 POSTS
sounds to me that your fuel delivery is the problem you need to change the fuel filter and check fuel pump pressure. if the fuel system checks ok then check for a restrition in the exhaust system such as cat converter
Jan 1, 2007 at 5:44 AM
BRUCE HUNT
  • 3,754 POSTS
Thanks ideisltech, that would be the exact place I would head quampus22 toward. Kind of reminds me of an old gentleman I knew who had a model T. They didn't have fuel pumps but used gravity to deliver the fuel pressure. He was in the Des Moines, Iowa area and there was a huge hill he needed to get up. He would take a run at the hill and about 3/4 of the way up it would die. He would coast back down and make another try. Same result. After about 3 tries, he noticed another car pull up and turn around. The owner backed up the hill and made it fine. He tried it and lo and behold he made it to the top. Gravity. So......
Either start backing up the hills and you will probably be just fine, except for a few accidents and law enforcement issues. Fuel delivery is the problem.
Jan 1, 2007 at 6:04 AM
Suggested Repair
Check fuel delivery first: replace the fuel filter and test fuel pump pressure. If the fuel system checks out, inspect the exhaust for a restriction such as a clogged catalytic converter.
Conversation Summary
The owner of a 1965 Honda reports loss of power and stalling while going uphill at 65 mph, even after replacing ignition parts. Replies point to fuel delivery and recommend changing the fuel filter, checking fuel pump pressure, and then checking for an exhaust restriction if fuel pressure is normal.
