Honda Spark Plug Ceramic Debris
HONDA
HONDAGUY1212
Hi yesterday I was replacing my sparkplugs on my honda and as I was removing the first sparkplug i head this crack noise so I ignored it then I heard another crack noise then i took the spark plug out and I looked at it and the ceramic part is all cracked and chipped and Now im very scared that there are little pieces sitting on My piston. :( What should I do?
thanks guys
Jun 7, 2006 at 6:04 AM
BRUCE HUNT
  • 3,754 POSTS
Have a good shop vac? Or access to one. By hand turn the engine so the piston is on top and then connect the vac to a short piece of garden hose and seal it somehow with tape etc to ensure maximum suction is still there to the end of the hose. Now put the hose into the hole or the top of the spark plug hole and let her suck. A good vac should pick up ever is laying in there.
Jun 12, 2006 at 4:01 AM
Suggested Repair
Turn the engine by hand until the piston is at the top, then use a shop vacuum connected to a short garden hose sealed with tape to suction ceramic debris from the spark plug hole.
Conversation Summary
While replacing spark plugs on a Honda, the owner cracked and chipped the ceramic insulator and worried fragments fell onto the piston. The expert recommended positioning the piston at the top and vacuuming the spark plug hole with a shop vac and a sealed hose.
