1988 Honda Civic Oil in Spark Plugs Fix
SKYLINE09
i own a 1988 honda civic 4 door with 271,000km on it. yesterday we changed the oil and afterward we checked the plugs to find that 2 of them had been soaked in oil. how can oil get into the spark plugs? and what could you do to fix this?
Aug 24, 2006 at 6:20 AM
BRUCE HUNT
  • 3,754 POSTS
There is a seal for each of the plug tubes and by taking off the valve cover you can get to the seals. Replace the valve cover and the seals usually come with it. Put everything in. They eventually will leak so I suggest fixing it soon.
Aug 24, 2006 at 8:45 AM
Suggested Repair
Replace the spark plug tube seals by removing the valve cover. A replacement valve cover usually includes the seals. Repair soon, as leaking seals will continue to let oil into the plug wells.
Conversation Summary
The owner of a 1988 Honda Civic with 271,000 km found two spark plugs soaked in oil after an oil change and asked how oil could reach the plugs. The expert explained that each plug tube has a seal under the valve cover that can leak, and recommended replacing the valve cover and seals soon.
