2000 Honda Civic Wrong Plugs and Cat Codes
MDKE025
I have a 2000 Honda Civic LX 148,000 miles. I had a tune up 4 months ago and had the wrong spark plugs put in, they were platinum and my car takes regular plugs. My check engine light came on and when i had it scanned it was a code for the catalytic converter and the o2 sensors. Whe i brought the car to honda they said they could not fix it under the warranty because the wrong spark plugs caused both the cat and the sensors to get fried. I went back to the place that did my tune up and tehy replaced the spark plugs and o2 sensors for free. They showed me the sensor and it was slightly cut, i have only driven 50 miles since this, and the check engine light hasnt come back on yet. Can having the wrong spark plugs really have caused these other parts to get fried?
Apr 6, 2007 at 7:54 AM
JOUGH626
  • 55 POSTS
NOPE. Don't beileve that. The spark plugs spark and light the fuel on fire, that's it. The have a temp range that operate at. Even if you had plugs that were grossly wrong, the O2 sensor would be fine and so would the cat. The Honda dealer was just trying to prey on your ignorance. You did the right thing to have mechanic replace the parts for parts honda would later agree to work with.
Apr 7, 2007 at 4:45 PM
LOSTINMARS
  • 222 POSTS
the o2 Sensor and cat on that car are a common failure. i have one scheduled for weds in my shop. i can't see how platinum plugs could cause this.
Apr 9, 2007 at 7:25 PM
  • 75,988 POSTS
[quote="lostinmars"]the o2 Sensor and cat on that car are a common failure. i have one scheduled for weds in my shop. i can't see how platinum plugs could cause this.[/quote
Apr 9, 2007 at 7:54 PM
Suggested Repair
Wrong platinum plugs did not fry the O2 sensors or catalytic converter; those failures are common on this Civic and unrelated to plug type. Plugs and O2 sensors were already replaced and the light is off, so monitor for returning codes and diagnose the converter and sensors separately if they come back.
Conversation Summary
A 2000 Honda Civic LX owner had platinum plugs installed instead of the specified plugs, then got catalytic converter and O2 sensor codes. The dealer blamed the plugs and denied warranty coverage. The tune-up shop replaced the plugs and O2 sensors at no charge, and the light stayed off after about 50 miles. Experts said spark plugs only ignite the mixture and would not damage the sensors or converter, and that those parts commonly fail on this car.
