Honda P1336 P1337 CSF Sensor
HONDA
MITCH56
I received the OBDII codes P1337 P1336 during an emission's test and failed. The message that I have found was CSF Sensor No Signal. Is this an easy fix or is this a shop issue? Any help would be greatly appreciated. Thanks all, Mitch
Sep 30, 2006 at 11:21 AM
BRUCE HUNT
  • 3,754 POSTS
Crankshaft Speed Fluctuation (CSF) Now, I am not for certain but I believe this sensor is located with the crankshaft position sensor behind the lower timing belt cover. It is kind of nestled back in there and though not terribly hard to replace I think they are replaced as one unit for about $200 (parts only). I would consult a repair manual for the exact location.
Oct 4, 2006 at 4:49 AM
Suggested Repair
Consult a repair manual for the exact location. The CSF sensor is believed to sit with the crankshaft position sensor behind the lower timing belt cover and is typically replaced as one unit, about $200 in parts.
Conversation Summary
A Honda owner failed an emissions test with codes P1336 and P1337, described as a CSF sensor no-signal condition, and asked whether it was an easy fix. The expert identified CSF as crankshaft speed fluctuation, said the sensor is likely located with the crankshaft position sensor behind the lower timing belt cover, and noted it is usually replaced as one unit for about $200 in parts, with a repair manual needed for the exact location.
