2003 Honda Accord Aft O2 Sensor
G3MANAZ
2003 Honda Accord EX, 40,500 miles, 2.4 liter eng.
I live in Florida. If my car is California emissions equipped, can I replace the aft O2 sensor with a non-Calif rated product, or does it have to have that specific (and much more expensive) part? Thank you very much.
Feb 9, 2007 at 4:30 AM
BRUCE HUNT
  • 3,754 POSTS
There are a number of aftermarket o2 sensors. However, some meet the california emissions and some don't. The Bosch O2 sensor meets it and is a direct replacement. Not sure which sensor you are looking for of the two on your vehicle. They seem to run about $65 to $100.
Feb 9, 2007 at 7:00 AM
G3MANAZ
Thanks Bruce,
The O2 sensor I need is for aft of the catalytic converter. The non-Calif emission one runs about $70-80, while the Calif emission one goes for $250 or more. I'm wondering if it's possible to put a non- Calif sensor on a system that is supposed to Calif. emission rated.
Feb 9, 2007 at 8:43 AM
LOSTINMARS
  • 222 POSTS
no its not possible to use a non cal-spec sensor and forget a universal. the cal-spec one should be whats called an air/fuel ratio sensor which is different than an oxygen sensor.
buy it from honda, trust me.
Feb 10, 2007 at 1:57 PM
BRUCE HUNT
  • 3,754 POSTS
From information I have gathered the Honda sensor is made by Bosch.
Feb 12, 2007 at 1:45 AM
LOSTINMARS
  • 222 POSTS
do what u want. i change them all the time. have fun.
Feb 12, 2007 at 11:14 PM
G3MANAZ
Thank you all. You've been very imformative!!
Feb 13, 2007 at 1:20 AM
Suggested Repair
Use the California-emissions-spec aft sensor, which may be an air/fuel ratio sensor rather than a standard oxygen sensor. Do not install a non-California or universal sensor; buy the correct Honda part (reportedly Bosch-made).
Conversation Summary
The owner of a 2003 Honda Accord asked whether a cheaper non-California aft O2 sensor could replace the California-emissions part. Experts said no: the California-spec sensor is required and may be an air/fuel ratio sensor, not a standard oxygen sensor. They advised buying the correct Honda sensor and avoiding universal or non-California parts.
