Honda Accord P1382 CYP Sensor
Suggested Repair
The cylinder position (CYP) sensor is inside the distributor, so the usual fix is to replace the whole distributor. A used distributor from a junkyard may be a lower-cost option. The sensor itself is the most likely failure, though wiring or a mechanical issue is also possible.
Conversation Summary
The owner of a 1996 Honda Accord with about 109,000 miles reported code P1382, cylinder position sensor no signal, and asked whether it was an electrical problem, a mechanical condition, a failed CYP sensor, and what repair would cost. The expert said the CYP sensor is in the distributor, a complete distributor is usually required, a junkyard unit may be cheaper, and the sensor is the suspected failure. A later owner of a 2002 Accord asked how critical a CYP error is and whether the car can be driven until repaired, but that question was not answered.
