2000 Honda Accord OBD Code P1382
2000 HONDA ACCORD
71,000 MILES • 4 CYL • FWD • AUTOMATIC
MRDONEGONE
Intermittent problem. Runs fine for awhile and then starts misfiring at 3K rpm. Registers code P1382, cyl misfire. Clear code and let sit a day or two and it runs fine for 30 minutes to an hour. Changed cap, rotor, spark plugs and wires. Runs fine as long as the enine runs below 3k rpm.
Mar 17, 2008 at 6:20 AM
P1382 relates to the cylinder position sensor-
The cylinder position sensor is part of the distributor and there is a 8-pin connector that the distributor plugs into. You need to unplug that and test the resistance on two of the wires that go to the cylinder sensor. The wire colors are orange and white. If the resistance is not within 350-700 ohms then either one of those wires is bad, or the sensor itself is bad/wiring/PCM.
Oct 10, 2017 at 10:08 AM
PJON
mrdonegone,
I have the same exact problem with my 2000 accord, and I was wondering if you had found a solution to your problem yet.
If so, could you explain to me how you fixed it.
Thanks
Pjon
