1991 Acura Integra Won't Pass 65 MPH
1965 HONDA
BIGCHRISTIAN2K2
I have a 91 Acura Integra with 200,000 miles on it. I let my sister drive it out of town and when she came back the car engine light came on. Now whenever i start the car up when the car is cold i can punch it. As soon as the engine light comes on i can't accelerate real fast the car jerks if i do and vibrates real hard. I get on the freeway and my car won't go pass 65 mph. If I stop the idle will go real low like its going to cut off. Sometimes it does.
Mar 18, 2006 at 12:09 PM
VANDRAGON
  • 298 POSTS
with that many miles, it sounds like the cat-converter is clogging up and will only get worse. good luck!
also if you smell that something is getting hot, the parkbrake could be stuck.
Mar 19, 2006 at 2:28 AM
BRUCE HUNT
  • 3,754 POSTS
Find the codes of the check engine light. It really sounds as though the computer in shutting down and causing the car to run in a default mode that does not read the sensors and adjust to outside conditoins, etc. Find the code.
Mar 20, 2006 at 6:03 AM
WGRACE07
  • 11 POSTS
[quote:f4bbc3b44d="bigchristian2k2"]I have a 91 Acura Integra with 200,000 miles on it. I let my sister drive it out of town and when she came back the car engine light came on. Now whenever i start the car up when the car is cold i can punch it. As soon as the engine light comes on i can't accelerate real fast the car jerks if i do and vibrates real hard. I get on the freeway and my car won't go pass 65 mph. If I stop the idle will go real low like its going to cut off. Sometimes it does.[/quote:f4bbc3b44d]
The jerking to the side sounds like one of your axles is broken--my car was doing that when I'd do an occasional peel out for fun and I just thought it was part of the process. Maybe she hit a really bad pothole or something; you could always pretend you know what she did and see if you can get her to admit to it.
Jun 6, 2009 at 7:03 PM
Suggested Repair
Retrieve the check engine codes first, since the car may enter a default mode once the light comes on. Also check the catalytic converter for clogging, and inspect the parking brake for dragging if there is a hot smell.
Conversation Summary
A 1991 Acura Integra with about 200,000 miles developed a check engine light after a trip. It accelerates normally when cold, but once the light comes on it jerks and vibrates under hard acceleration, will not exceed about 65 mph, and sometimes idles very low or stalls. Experts advised reading the trouble codes, checking for a clogged catalytic converter, and noting a stuck parking brake if something smells hot.
