1990 Acura Integra Sudden Stall
STYLEZD23
my car(1990 Acura Integra RS) was running fine when the engine just shuts off and rpm gauge fell from 3000 rpm to 0. It happened before and it started fine. I tried starting it this time and it would not start. After not touching it for several hours I tried starting it once again but it wouldn't...I was thinking that I flooded it. Now i don't know what happened when the engine just shuts off. Can somebody help me
Jan 1, 2006 at 6:47 AM
  • 55,837 POSTS
Check your distributor, remove the distributor cap to inspect for rust color powder. If present replace the distributor with new.
Jan 1, 2006 at 12:32 PM
STYLEZD23
after taking it to the mechanic..he said that there was a problem with the igniter
Jan 2, 2006 at 11:51 AM
STYLEZD23
how much would it cost to change the clutch? mine's almost worn out
Jan 3, 2006 at 5:20 PM
Suggested Repair
Remove the distributor cap and inspect for rust-colored powder. If that powder is present, replace the distributor.
Conversation Summary
The owner of a 1990 Acura Integra RS reported that the engine suddenly shut off while running and then would not restart. An expert advised checking the distributor cap for rust-colored powder and replacing the distributor if it was found. The owner later said a mechanic identified an igniter problem and asked about the cost of replacing a worn clutch, but that question was not answered.
