I replaced the entire distributor, is the coil seperate from the coil on the distributor. Are you refering to the ignition coil? Where would I locate the coil you are refering too and how big of a job is it?
An upddate, the engine hasn't died on me yet while running since I changed the Distribtuor, but the first night after it woudln't let me restart it for about 15 mins of playing, as stated in my original note. Since that little episode so far so good, but I know it will happen again. Does it still sound like the coil to you? IF so excellent I will see if I can replace that.
Another thing I was wondering is could it be the brick in the catalytic converter has come loose and some times it slips around and clogs the exhausts airway causing it to not start. Cause my cat rattles like you wouldn't believe off and on right now from bottoming out too many times directly onto it on speed bumps.
Any help would be appreciated, thanks
SPONSORED LINKS
Sunday, January 8th, 2006 AT 12:51 PM
