Impala cuts off at will
LADYIRVING
I am the second owner of a 2000 4dr Impala. My mileage is 107K, automatic, 4 whl drive. The car began to randonly cut off three yrs ago around 85k. then it only would do so in cold temps with the heat high. in june 2005, it would cut off on hot days. i have been to three chevy dealerships & the car was in the shop for all of 2006. the battery light comes on and the steering wheel get stiff. sometimes it starts right up and others it takes a while. it does not make a sound when it cuts off. when trying to start it up, sometimes i cannot hear the fuel drop in the back. the dealers have replaced the: oxygen sensor, catalytic converter, transmission sensor, fuel pump, reset the computer. the car has a slow oil leak and increasingly shuts itself off.
I went to Branch Electric to run tests and nothing came back. the check engine light usually comes on once the car cuts off. sometimes it stays on, other times it goes out. when the dealer read the codes, it was a different set of codes each time. one time they drove my car, it cut off and he wrote down the codes. got to the shop literally five minutes later and an entirely new set of codes appeared. (thus resetting the computer)i love my car, it is the first i purchased on my own, please, please, please help me.
Sep 21, 2007 at 8:35 AM
FISHERMAN
  • 937 POSTS
Hi lady...
Do you write down the codes that come out from the computer?
Sep 21, 2007 at 9:04 AM
FANCYCARMEN
Just checking what you found out on the Impala intermittently dying. I have a 2001 that is doing the same thing. It will not set any codes.
Dec 5, 2007 at 2:04 PM
FANCYCARMEN
Found It! Mass Air Flow Sensor.
Dec 10, 2007 at 6:10 PM
