Honda Brake Light Warning Stays On
HONDA
TANNER.
  • 7 POSTS
One of my right brake lights went out, so I replaced it.. yet the brake light warning light on my dash is still lit up.. how do I make it go away? all my brake lights are working fine now..
May 27, 2006 at 1:36 PM
BRUCE HUNT
  • 3,754 POSTS
Check the fuses.
May 29, 2006 at 3:27 PM
BOND007
  • 5 POSTS
Does the brake light come on even though u see the warning light if so it could be a short, if not it could be the fuse. More likely to be the fuse.
Jun 2, 2006 at 6:27 AM
Suggested Repair
Check the brake-light fuses. If a brake lamp still does not light while the warning is on, also inspect for a short; if all lamps work, a fuse problem is more likely.
Conversation Summary
The owner replaced a failed right brake-light bulb, but the dash warning stayed on even though all brake lights now work. An expert advised checking the fuses. Another reply said a short is possible if a lamp still fails to light, but a fuse problem is more likely.
