1987 Honda Accord LX Hot No Spark
HONDA
ROBERTHARVEY
I have a 87 honda acord lx and it dies when it gets hot and there is no spark and i have replaced the coil but it still does it but when it sits for awile it will start again and get warm and stop again :twisted: :twisted: i have been trying to fix it and cant figure it out at all please help
Apr 1, 2006 at 8:36 AM
LOSONE
  • 1,616 POSTS
The most probable cause is the EFI relay. It is located under the dash high up about where you left knee is on a left hand drive car.
It is a balck metal relay a little larger than most and is secured with a 10mm bolt. It is a common failure on your vehicle.
you need a 3 foot person with 4' arms to get it out. It is a dealer only item and about $100.00+ (US)
Apr 3, 2006 at 11:20 AM
ROBERTHARVEY
it isnt efi but does it still have the relay
Apr 5, 2006 at 3:28 PM
RUBYC
  • 6 POSTS
I have a 93 Honda civic and mine was doing the same thing. I just got it fixed, it was the relay. Cost me about 90 including labor. ($20 labor) I got my coil replaced for 200 last year and it wasn't the problem!
But it hasn't been having trouble since I just got it fixed 2 weeks ago, and it's been hot here. Good luck
Apr 20, 2006 at 5:30 PM
Suggested Repair
Replace the under-dash EFI relay (black metal relay, larger than typical, held by a 10 mm bolt near the left-knee area on a left-hand-drive car). It is a common cause of hot no-spark after the coil has already been replaced and is often a dealer part around $100.
Conversation Summary
The owner of a 1987 Honda Accord LX says it dies when hot with no spark. The coil was already replaced; after cooling it starts, then stalls again once warm. An expert identifies the EFI relay under the dash as the most likely cause. The owner asks whether a non-EFI car still has that relay. Another owner with the same hot no-spark symptom on a 1993 Honda Civic reports the relay, not the coil, fixed it for about $90.
