1995 Other Honda Models
1995 HONDA
143,654 MILES • 4 CYL • FWD • AUTOMATIC
JEWAN BUCHOON
MY ENGINE CHECK LIGHT COMES ON AND OFF AND MY SPEED -O-METER SHUTS DOWN ALSO THE DRIVE LIGHT THE 'D' GEAR SHIFT ON THE DASHBOARD KEEPS BLINKING
Jan 7, 2009 at 10:28 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
The flashing "D" on the instrument panel is a feature that your vehicle uses to let the driver know there is a fault found in the transmission system. This could be wiring faults or more serious issues such as pressure problems within the transmission.
The TCU (transmission control unit) of this vehicle is very common to go faulty and cause the symptoms you are experiencing. You may want to have a reputable transmission shop run a diagnostic test on it to see what component is going bad.
Hope this helps..
Thanks for using 2carpros.com!
Jan 7, 2009 at 6:23 PM
