1991 Acura Integra Manual Swap
HONDA
FLYINEAGLE
I drive a 1991 acura integra ls, it has 315000 kms on it and i was wondering how much work/money it would take to switch it over to a 5 speed manual transmission
May 8, 2006 at 5:55 AM
LOSONE
  • 1,616 POSTS
I always say any thing made by man can be fixed by man.
I did a swap a few years ago on a civic. The brackets are all in place so all you have to do is go to a salvage yard and get the standard set up including the master and slave units. It will require an axle change and a computer swap.
It will cost a lot more than replacing an automatic. about 3X
Good luck
May 8, 2006 at 7:00 AM
Suggested Repair
Source a complete manual transmission setup from a salvage yard, including the clutch master and slave units. Plan on changing the axles and swapping the computer. Expect the conversion to cost roughly three times as much as replacing the automatic transmission.
Conversation Summary
The owner of a high-mileage 1991 Acura Integra LS asked how much work and money it would take to convert it to a 5-speed manual. The expert said the brackets are already in place and recommended obtaining the complete manual setup, including master and slave units, from a salvage yard, along with changing the axles and swapping the computer. The conversion was estimated to cost about three times as much as replacing the automatic.
