1990 Acura Integra Clutch Replacement Cost
HONDA
STYLEZD23
how much will it cost to replace a clutch for an 1990 integra rs?
do u suggest high performance clutch?
Apr 26, 2006 at 4:18 PM
BRUCE HUNT
  • 3,754 POSTS
OEM. High performance clutches really don't last any longer. I would think you should be watching your driving habits. Some people are notorious for letting the foot hover over the pedal and without knowing it they are riding the clutch. Premature failure will result.
Cost not really sure but labor could run around $300 with parts around 200 to 250.
Apr 28, 2006 at 6:15 AM
Suggested Repair
Replace the clutch with an OEM unit rather than a high-performance clutch, which does not last longer. Expect roughly $300 labor and $200 to $250 in parts. Avoid riding the clutch pedal to prevent premature wear.
Conversation Summary
The owner asked about clutch replacement cost for a 1990 Acura Integra RS and whether a high-performance clutch is recommended. The expert advised an OEM clutch, noted that performance clutches do not last longer, warned against riding the pedal, and estimated labor around $300 with parts around $200 to $250.
