1988 Honda Clutch Won't Disengage
HONDA
JOEJOE530
i have a 1988 honda 5 speed stick shift,when the car is started up i push the clutch in and it wont shift into first second,third,fourth,or fifth and even reverse,so i turned it off then put it in first then when i started it up again it wants to take off even though the clutch is still engaged,could i be low on gearcase oil,or could it be the prssure plate
Jul 2, 2007 at 1:48 AM
BRUCE HUNT
  • 3,754 POSTS
Is that a cable or hydraulic system. That clutch is not right and it could be a cable adjustment or it is time for a clutch replacement. Check the cable first.
Jul 2, 2007 at 2:14 AM
Suggested Repair
Determine whether the clutch is cable- or hydraulic-operated, then check and adjust the clutch cable first. If adjustment does not restore release, replace the clutch.
Conversation Summary
The owner of a 1988 Honda five-speed says the transmission will not shift into any gear, including reverse, with the clutch pedal pressed, and the car tries to move when started in first with the pedal still down. The expert says the clutch is not releasing properly and recommends identifying cable versus hydraulic actuation, checking cable adjustment first, and replacing the clutch if adjustment does not fix it.
