Cracked Transmission Mount. Could this be the problem?
HONDA
6E LUDE
  • 6 POSTS
Well Im sure some of you know that my axle kept on popping out of my transmission. I thought I might be the transmission. But I looked at my Transmission Mount and it was cracked. Would a cracked Transmission Mount cause a axle to vibrate/pop out of the tranny because of the movement?
Nov 9, 2006 at 7:01 AM
BRUCE HUNT
  • 3,754 POSTS
I hope you know the answer to that. The engine really puts pressure on the mounts. Take any powerful electric motor and hold it in your hand. Turn it on and you feel that snap as it kicks on. Many are hard to hold. Some old drills would literally jump out of your hand. That snap and the cracked mount let that engine move too much. I have had a mount fail on an old honda and the axles will pull out easily. Have it welded or brazed or replaced and the problem dissappears.
Nov 9, 2006 at 6:33 PM
6E LUDE
  • 6 POSTS
Thanks for the help.
I bought a brand new one from Honda.
Not cheap, but I needed it asap,
and they were the only people who had it.
Nov 10, 2006 at 12:19 AM
