1994 Acura Integra Hard Shifting
RIDETHROUGHLIFE
  • 13 POSTS
1994 integra ls automatic. i bought it 7k miles ago. it idles fine. the entire time ive had it it seems to shift hard, a lot harder than my older 1993 one did, also auto. it also seems to not want to downshift when i press the petal. any ideas on this issue? from what i can tell it may be something simple like a tranny flush that could fix it, unless it isnt a small thing, but im not sure. it hasnt affected the performance of the car, ive put the 7k miles on it in only 3 months, so its doing great. but id like to keep it a long time and would prefer i know what this problem is.
Oct 18, 2007 at 4:34 PM
BRUCE HUNT
  • 3,754 POSTS
You mentioned the flush and that is exactly where I would start.
Oct 19, 2007 at 2:44 AM
RIDETHROUGHLIFE
  • 13 POSTS
is that something i could do easily on my car, or should i get it done somewhere? and wheres a good place to get it done, cheap?
Oct 19, 2007 at 4:31 AM
BRUCE HUNT
  • 3,754 POSTS
A trusted mechanic can probably do this for you. I would not attempt to do it myself as a typical user does not have the proper equipment.
Oct 21, 2007 at 10:19 AM
Suggested Repair
Have a trusted mechanic perform a transmission flush. Do not attempt the flush yourself without the proper equipment.
Conversation Summary
The owner of a 1994 Acura Integra LS automatic reports hard shifting and reluctance to downshift when the accelerator is pressed. The expert recommends starting with a transmission flush and having a trusted mechanic do it rather than attempting it without proper equipment.
