Honda Takeoff Chatter After Missed Gear
HONDA
00HONDACIVIC
  • 16 POSTS
Last night was driving my car and i missed third gear. After that it was kinda grinding and was real shakey at first on take off. then it kinda shook it off. now every time i take off in the low rpm range in any gear its real shakey kinda of feels like its grinding unless i give it good gas. other than that it reaches it rpms but feels like its holding back kinda then somtimes it fress up. Its usually real loose and the rpms race up real quick with ease in neutral. I have a gsr tranny. Coes ne body know the problem? Thnx in advance
Mar 30, 2006 at 4:13 PM
LOSONE
  • 1,616 POSTS
Sounds like a broken third gear syncronizer in the tranny. Drain the tranny and inspect the fluid. If you have metal pieces epecially brass go look for another tranny. Make sure you put the correct fluid back in the tranny. It is NOT the clutch
How many miles on the Honda?
Good luck
Mar 31, 2006 at 12:44 AM
00HONDACIVIC
  • 16 POSTS
The motror has about thirty thousand had a swap done two years ago.
Mar 31, 2006 at 3:54 AM
00HONDACIVIC
  • 16 POSTS
The deal is its not grinding its chattering vibrating when i take off but it still hitting rpms normally only on the take off it does the chattering. Is this still the transmission?
Mar 31, 2006 at 6:20 AM
LOSONE
  • 1,616 POSTS
Chattering is normally a clutch but it started when you hit 3 gear sans clutch. As I said before, service the tranny by changing the oil. Look at the fluid, it is going to be a big factor. If it is full of metal them you know it's the tranny.
Put the energency brake on solid, put tranny in 2nd gear and let out the clutch without stalling the engine and see if you get chatter. Then try 3rd gear and then 1st gear. Don't burn the clutch. If it is a clutch, all 3 will react the same with the same chatter if not tranny.
Mar 31, 2006 at 9:16 AM
00HONDACIVIC
  • 16 POSTS
I did what you said and it does the same thing in every gear. guess its the clutch
Apr 1, 2006 at 12:34 PM
Suggested Repair
Inspect and replace the clutch as needed. The parking-brake test produced the same chatter in every gear, which indicates a clutch problem rather than a transmission synchronizer. Do not overheat the clutch during testing. If the transmission fluid is drained, inspect it for metal and refill with the correct fluid.
Conversation Summary
The owner of a Honda with a GSR transmission reported shaking and chatter on takeoff after missing third gear, while the engine revved freely in neutral. An expert first suspected a broken third-gear synchronizer and advised checking the fluid for metal. After the owner clarified that the symptom was chatter only during takeoff, the expert recommended a parking-brake test in multiple gears. The same chatter in every gear indicated the clutch rather than the transmission.
