1993 Honda won't stay started
CAPTAINKURT
  • 1993 HONDA
My 1993 honda won't stay started. I was driving down the street to go put some gas in my car because it was low. Then I ran out of gas, so I coasted to the gas station. After filling my gas up to half way, it started up again but once I got back on the road it cut off. I tried several times and it will run for a little bit and turn off. What should I do?
Friday, June 9th, 2006 AT 7:11 PM
CODY-ODY
  • 57 POSTS
You have to find out if its fuel related or you have another problem that just arose at the some time. I do know that these models had a problem with their ignition switches and the car would just shut off on its own but it would restart again for A LITTLE WHILE.
Tuesday, June 20th, 2006 AT 6:03 PM
BRUCE HUNT
  • 3,754 POSTS
Did the check engine light come on?
Wednesday, June 21st, 2006 AT 3:54 PM
VANDRAGON
  • 298 POSTS
Start the car and keep your had on the key. Let it run until it starts to die. Quickly put a little turning pressure on the key (like your going to start it again) if I keeps running, it's the switch. Being a 93 it could be anything. Best to take it some where and have it scanned for codes.
Saturday, June 24th, 2006 AT 7:14 AM
