1993 Honda Del Sol Overheating Gauge
BATOONP
i have a 93 honda del sol type s with over 140000 miles. When i first bought the car, it ran fine, but the temperature gauge only raised slighlty above the C when i drove it. After some months, the temperature reading now gradually inceases, and as it moves close to the middle the car stalls, and the check engine light, oil light, and battery light turn on. When i pull over, and let the car idle, the warning lights shut off. THen i turn on the heater full blast and the temperature drops about a quarter and remains constant. Then i roll down the windows and drive off. With the heater on, i have no problems with my car when it acts up. what's going on, is it my thermostat, is there sludge build up (where), or do i have leaks?
Mar 17, 2007 at 2:49 PM
BRUCE HUNT
  • 3,754 POSTS
First of all the temp gauge appears to be faulty. When it raised a slight amount it should have been telling you it was overheating and have been pegging to the max temp.
Check the coolant in the vehicle, check for leaks, and also check to make sure there is no air in the system. Watch the car closely for leaks and white smoke. In the meantime, have the thermostat removed and replaced.
Mar 19, 2007 at 6:49 AM
Suggested Repair
Check the coolant level, look for leaks and white smoke, and bleed any air from the cooling system. Replace the thermostat. The temperature gauge may also be faulty and not showing true overheating.
Conversation Summary
The owner of a 1993 Honda Del Sol says the temperature gauge barely rose at first, then later climbs toward the middle, the engine stalls, and the check engine, oil, and battery lights come on. Idling and running the heater lowers the reading, and the car drives normally with the heater on. The expert says the gauge may be faulty and not showing actual overheating, and advises checking coolant, leaks, and air in the system, watching for white smoke, and replacing the thermostat.
